Multi-Phase Task-Based HPC Applications: Quickly Learning how to Run Fast - Archive ouverte HAL Access content directly
Conference Papers Year :
Parallel applications performance strongly depends on the number of resources. Although adding new nodes usually reduces execution time, excessive amounts are often detrimental as they incur substantial communication overhead, which is difficult to anticipate. Characteristics like network contention, data distribution methods, synchronizations, and how communications and computations overlap generally impact the performance. Finding the correct number of resources can thus be particularly tricky for multi-phase applications as each phase may have very different needs, and the popularization of hybrid (CPU+GPU) machines and heterogeneous partitions makes it even more difficult. In this paper, we study and propose, in the context of a task-based GeoStatistic application, strategies for the application to actively learn and adapt to the best set of heterogeneous nodes it has access to. We propose strategies that use the Gaussian Process method with trends, bound mechanisms for reducing the search space, and heterogeneous behavior modeling. We compare these methods with traditional exploration strategies in 16 different machines scenarios. In the end, the proposed strategies are able to gain up to ≈51% compared to the standard case of using all the nodes while having low overhead.
2022029591.pdf (2.32 Mo) Télécharger le fichier
Dates and versions
hal-03608579 , version 1 (14-03-2022)
Identifiers
  • HAL Id : hal-03608579 , version 1
Cite
Lucas Nesi, Lucas Mello Schnorr, Arnaud Legrand. Multi-Phase Task-Based HPC Applications: Quickly Learning how to Run Fast. IPDPS 2022 - 36th IEEE International Parallel & Distributed Processing Symposium, May 2022, Lyon, France. pp.1-11. ⟨hal-03608579⟩
115 View
97 Download
Share
