Programming Heterogeneous Architectures Using Hierarchical Tasks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2022
Programmation des Architectures Hétérogènes à l'Aide de Tâches Hiérarchiques
Task-based systems have gained popularity because of their promise of exploiting the computational power of complex heterogeneous systems. A common programming model is the so-called Sequential Task Flow (STF) model, which, unfortunately, has the intrinsic limitation of supporting static task graphs only. This leads to potential submission overhead and to a static task graph which is not necessarily adapted for execution on heterogeneous systems. A standard approach is to find a trade-off between the granularity needed by accelerator devices and the one required by CPU cores to achieve performance. To address these problems, we extend the STF model in the StarPU runtime system to enable tasks subgraphs at runtime. We refer to these tasks as hierarchical tasks. This approach allows for a more dynamic task graph. This extended model combined with an automatic data manager allows to dynamically adapt the granularity to meet the optimal size of the targeted computing resource. We show that the hierarchical task model is correct and we provide an early evaluation on shared memory heterogeneous systems, using the Chameleon dense linear algebra library
Les systèmes à base de tâches ont gagné en popularité du fait de leur capacité à exploiter pleinement la puissance de calcul des architectures hétérogènes complexes. Un modèle de programmation courant est le modèle de soumission séquentielle de tâches (Sequential Task Flow, STF) qui malheureusement ne peut manipuler que des graphes de tâches statiques. Ceci conduit potentiellement à un surcoût lors de la soumission, et le graphe de tâches statique n'est pas nécessairement adapté pour s'exécuter sur un système hétérogène. Une solution standard consiste à trouver un compromis entre la granularité permettant d'exploiter la puissance des accélérateurs et celle nécessaire à la bonne performance des CPUs. Pour répondre à ces problèmes, nous proposons d'étendre le modèle STF fourni par le support d'exécution StarPU en y ajoutant la possibilité de transformer certaines tâches en sous-graphe durant l'exécution. Nous appelons ces tâches des tâches hiérarchiques. Cette approche permet d'exprimer des graphes de tâche plus dynamiques. En combinant ce nouveau modèle à un gestionnaire automatique des données, il est possible d'adapter dynamiquement la granularité pour fournir une taille optimale aux différentes ressources de calcul ciblées. Nous montrons dans ce rapport que le modèle des tâches hiérarchiques est valide ainsi qu'une première évaluation de ses performances en utilisant la bibliothèque d'algèbre linéaire dense Chameleon.
RR-9466.pdf (671.99 Ko) Télécharger le fichier
hal-03609275 , version 1 (15-03-2022)
hal-03609275 , version 2 (01-04-2022)
  • HAL Id : hal-03609275 , version 2
Mathieu Faverge, Nathalie Furmento, Abdou Guermouche, Gwenolé Lucas, Raymond Namyst, et al.. Programming Heterogeneous Architectures Using Hierarchical Tasks. [Research Report] RR-9466, Inria Bordeaux Sud-Ouest. 2022, pp.21. ⟨hal-03609275v2⟩
251 Consultations
287 Téléchargements
