EXtremely PRIvate supervised Learning - Archive ouverte HAL Access content directly
Conference Papers Year : 2021
This paper presents a new approach called ExPriL for learning from extremely private data. Iteratively, the learner supplies a candidate hypothesis and the data curator only releases the marginals of the error incurred by the hypothesis on the privately-held target data. Using the marginals as supervisory signal, the goal is to learn a hypothesis that fits this target data as best as possible. The privacy of the mechanism is provably enforced, assuming that the overall number of iterations is known in advance.
CAp2021_paper_33.pdf (449.95 Ko) Télécharger le fichier
Dates and versions
hal-03620873 , version 1 (27-03-2022)
Identifiers
  • HAL Id : hal-03620873 , version 1
Cite
Armand Lacombe, Saumya Jetley, Michèle Sebag. EXtremely PRIvate supervised Learning. Conférence d'APprentssage - CAP, Jun 2021, St-Etienne, France. ⟨hal-03620873⟩
38 View
21 Download
Share
