EXtremely PRIvate supervised Learning
This paper presents a new approach called ExPriL for learning from extremely private data. Iteratively, the learner supplies a candidate hypothesis and the data curator only releases the marginals of the error incurred by the hypothesis on the privately-held target data. Using the marginals as supervisory signal, the goal is to learn a hypothesis that fits this target data as best as possible. The privacy of the mechanism is provably enforced, assuming that the overall number of iterations is known in advance.
Intelligence artificielle [cs.AI]
