Finding Good Configurations of Planar Primitives in Unorganized Point Clouds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present an algorithm for detecting planar primitives from unorganized 3D point clouds. Departing from an initial configuration, the algorithm refines both the continuous plane parameters and the discrete assignment of input points to them by seeking high fidelity, high simplicity and high completeness. Our key contribution relies upon the design of an exploration mechanism guided by a multiobjective energy function. The transitions within the large solution space are handled by five geometric operators that create, remove and modify primitives. We demonstrate the potential of our method on a variety of scenes, from organic shapes to man-made objects, and sensors, from multiview stereo to laser. We show its efficacy with respect to existing primitive fitting approaches and illustrate its applicative interest in compact mesh reconstruction, when combined with a plane assembly method.
CVPR22_Mulin.pdf (18.23 Mo) Télécharger le fichier
CVPR22_Mulin_supplementary.pdf (11.18 Mo) Télécharger le fichier
Format : Figure, Image
hal-03621896 , version 1 (28-03-2022)
  • HAL Id : hal-03621896 , version 1
Mulin Yu, Florent Lafarge. Finding Good Configurations of Planar Primitives in Unorganized Point Clouds. CVPR 2022 - IEEE Conference on Computer Vision and Pattern Recognition, Jun 2022, La Nouvelle-Orléans, United States. ⟨hal-03621896⟩
404 Consultations
518 Téléchargements
