Separation Analysis for Weakest Precondition-based Verification
The component-as-array model is a widely used technique for modeling heap memory in Weakest Precondition-based deductive verification of pointer programs. We propose a separation analysis which can be integrated in the core of this model. This allows to greatly simplify the verification conditions generated, and thus greatly helps in proving such pointer programs. We illustrate the improvements both in term of scaling up for codes of large size, and in term of simplification of the reasoning for establishing advanced behaviors.
Logique en informatique [cs.LO]
