A study on the impact of the distance types involved in protein structure determination by NMR - Archive ouverte HAL Access content directly
Conference Papers Year :
The Distance Geometry Problem (DGP) consists of finding the coordinates of a given set of points where the distances between some pairs of points are known. The DGP has several applications and one of the most relevant ones arises in the context of structural biology, where NMR experiments are performed to estimate distances between some atom pairs in a given molecule, and the possible conformations for the molecule are calculated through the formulation and the solution of a DGP. We focus our attention on DGP instances for which some special assumptions allow us to discretize the DGP search space and to potentially perform the complete enumeration of the solution set. We refer to the subclass of DGP instances satisfying such discretizability assumptions as the Discretizable DGP (DDGP). In this context, we propose a new procedure for the generation of DDGP instances where real data and simulated data (from known molecular models) can coexist. Our procedure can give rise to peculiar DDGP instances that we use for studying the impact of every distance type, involved in NMR protein structure determination, on the quality of the found solutions. Surprisingly, our experiments suggest that the distance types implying a larger effect on the solution quality are not the ones related to NMR data, but rather the more abundant, but much less informative, van der Waals distance type.
bibm21_distance_geometry.pdf (632 Ko) Télécharger le fichier
Dates and versions
hal-03636295 , version 1 (09-04-2022)
Identifiers
  • HAL Id : hal-03636295 , version 1
Cite
Simon Hengeveld, Therese Malliavin, Jung-Hsin Lin, Leo Liberti, Antonio Mucherino. A study on the impact of the distance types involved in protein structure determination by NMR. BIBM 2021 - IEEE International Conference on Bioinformatics and Biomedicine, Dec 2021, Houston, United States. pp.1-9. ⟨hal-03636295⟩
41 View
34 Download
Share
