Class-distinctiveness-based frequency band selection on the Riemannian manifold for oscillatory activity-based BCIs: preliminary results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Considering user-specific settings is known to enhance Brain-Computer Interface (BCI) performances. In particular, the optimal frequency band for oscillatory activity classification is highly user-dependent and many frequency band selection methods have been developed in the past two decades. However, it is not well studied whether those conventional methods can be efficiently applied to the Riemannian BCIs, a recent family of BCI systems that utilize the non-Euclidean nature of the data unlike conventional BCI pipelines. In this paper, we proposed a novel frequency band selection method working on the Riemannian manifold. The frequency band is selected considering the class distinctiveness as quantified based on the inter-class distance and the intra-class variance on the manifold. An advantage of this method is that the frequency bandwidth can be adjusted for each individual without intensive optimization steps. In a comparative experiment using a public dataset of motor imagery-based BCI, our method showed a substantial improvement in average accuracy over both a fixed broad frequency band and a popular conventional frequency band selection method. In particular, our method substantially improved performances for subjects with initially low accuracies. This preliminary result suggests the importance of developing new user-specific setting algorithms considering the manifold properties, rather than directly applying methods developed prior to the rise of the Riemannian BCIs.
EMBC2022_camera_ready_v2.pdf (165.41 Ko) Télécharger le fichier
hal-03641137 , version 1 (14-04-2022)
hal-03641137 , version 2 (23-01-2023)
Maria Sayu Yamamoto, Fabien Lotte, Florian Yger, Sylvain Chevallier. Class-distinctiveness-based frequency band selection on the Riemannian manifold for oscillatory activity-based BCIs: preliminary results. EMBC 2022- 44th Annual International Conference of the IEEE Engineering in Medicine & Biology Society, Jul 2022, Glasgow, United Kingdom. ⟨10.1109/EMBC48229.2022.9871820⟩. ⟨hal-03641137v2⟩
298 Consultations
246 Téléchargements
