Experimental code and results for the paper "Symmetric Block-Cyclic Distribution: Fewer Communications leads to Faster Dense Cholesky Factorization" - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Logiciel Année : 2022
This archive contains all relevant information to build the software stack used for the experiments presented in the paper "Symmetric Block-Cyclic Distribution: Fewer Communications leads to Faster Dense Cholesky Factorization". It also contains scripts to re-run those experiments and new ones and process the results. All results presented in the paper are archived here as well.
Olivier Beaumont, Philippe Duchon, Julien Langou, Lionel Eyraud-Dubois, Mathieu Verite. Experimental code and results for the paper "Symmetric Block-Cyclic Distribution: Fewer Communications leads to Faster Dense Cholesky Factorization". 2022, ⟨swh:1:dir:ec92870dfc2a7e7c8a6e87914823e25bc651a5b7;origin=https://hal.archives-ouvertes.fr/hal-03643569;visit=swh:1:snp:6b8402b24d2133d01fc48d0f01d83f605cc77898;anchor=swh:1:rel:3068c5a3c30d3a673a553d033029929a03ddb4cf;path=/⟩. ⟨hal-03643569v2⟩
Collections
CNRS INRIA INRIA2
200 Consultations
37 Téléchargements
