IO-SETS: Simple and efficient approaches for I/O bandwidth management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
One of the main performance issues faced by highperformance platforms is the delay caused by concurrent applications performing I/O. When this happens, applications sharing the I/O bandwidth create congestion, which delays the execution time and affects the platform's overall performance. Several solutions have been proposed to tackle I/O congestion. Among those solutions, I/O scheduling strategies are an essential solution to this problem in HPC systems. Currently, their main drawback is the amount of information needed. In this work, we propose a novel framework for I/O management, IO-SETS. We present the potential of this framework through a simple scheduling solution called SET-10, an I/O scheduling solution that demands minimum information from users and can be easily integrated into HPC environments.
long_main.pdf (843.91 Ko) Télécharger le fichier
hal-03648225 , version 1 (21-04-2022)
hal-03648225 , version 2 (05-05-2022)
hal-03648225 , version 3 (19-08-2023)
  • HAL Id : hal-03648225 , version 2
Francieli Boito, Guillaume Pallez, Luan Teylo, Nicolas Vidal. IO-SETS: Simple and efficient approaches for I/O bandwidth management. 2022. ⟨hal-03648225v2⟩
403 Consultations
257 Téléchargements
