Time-synchronization of interventional cardiovascular magnetic resonance data using a biomechanical model for pressure-volume loop analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Magnetic Resonance Imaging Année : 2023
JMRI_extended_research_letter_submission_2022_04_14.pdf (346.44 Ko) Télécharger le fichier
hal-03651166 , version 1 (25-04-2022)
Maria Gusseva, Daniel Castellanos, Joshua Greer, Mohamed Hussein, Keren Hasbani, et al.. Time-synchronization of interventional cardiovascular magnetic resonance data using a biomechanical model for pressure-volume loop analysis. Journal of Magnetic Resonance Imaging, 2023, 57 (1), pp.320-323. ⟨10.1002/jmri.28216⟩. ⟨hal-03651166⟩
78 Consultations
188 Téléchargements
