Kernel representation of Kalman observer and associated H-matrix based discretization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Control, Optimisation and Calculus of Variations Année : 2022
In deterministic estimation, applying a Kalman filter to a dynamical model based on partial differential equations is theoretically seducing but solving the associated Riccati equation leads to a so-called curse of dimensionality for its numerical implementation. In this work, we propose to entirely revisit the theory of Kalman filters for parabolic problems where additional regularity results proves that the Riccati equation solution belongs to the class of Hilbert-Schmidt operators. The regularity of the associated kernel then allows to proceed to the numerical analysis of the Kalman full space-time discretization in adapted norms, hence justifying the implementation of the related Kalman filter numerical algorithm with H-matrices typically developed for integral equations discretization.
cocv210234.pdf (17.6 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03911500 , version 1 (22-12-2022)
Paternité
Matthieu Aussal, Philippe Moireau. Kernel representation of Kalman observer and associated H-matrix based discretization. ESAIM: Control, Optimisation and Calculus of Variations, 2022, 28, pp.78. ⟨10.1051/cocv/2022071⟩. ⟨hal-03911500⟩
227 Consultations
76 Téléchargements
