Quasi-explicit, unconditionally stable, discontinuous galerkin solvers for conservation laws - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2022
We have developed in a previous work a parallel and quasi-explicit Discontinuous Galerkin (DG) kinetic scheme for solving hyperbolic systems of conservation laws. The solver is unconditionally stable (i.e., the CFL number can be arbitrary), has the complexity of an explicit scheme. It can be applied to any hyperbolic system of balance laws. In this work, we improve the parallel scaling of the method thanks to an implicit-explicit subdomain decomposition strategy.
bc-kin-helluy.pdf (1.18 Mo) Télécharger le fichier
hal-03665248 , version 1 (11-05-2022)
  • HAL Id : hal-03665248 , version 1
Philippe Helluy, Pierre Gerhard, Victor Michel-Dansac, Bruno Weber. Quasi-explicit, unconditionally stable, discontinuous galerkin solvers for conservation laws. [Research Report] IRMA (UMR 7501). 2022. ⟨hal-03665248⟩
78 Consultations
27 Téléchargements
