Upper and lower bounds for the maximal Lyapunov exponent of singularly perturbed linear switching systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2023
In this paper we consider the problem of determining the stability properties, and in particular assessing the exponential stability, of a singularly perturbed linear switching system. One of the challenges of this problem arises from the intricate interplay between the small parameter of singular perturbation and the rate of switching, as both tend to zero. Our approach consists in characterizing suitable auxiliary linear systems that provide lower and upper bounds for the asymptotics of the maximal Lyapunov exponent of the linear switching system as the parameter of the singular perturbation tends to zero.
SlowFast.pdf (388.94 Ko) Télécharger le fichier
hal-03668881 , version 1 (16-05-2022)
Paternité
Yacine Chitour, Ihab I. Haidar, Paolo Mason, Mario Sigalotti. Upper and lower bounds for the maximal Lyapunov exponent of singularly perturbed linear switching systems. Automatica, 2023, 155, pp.111151. ⟨10.1016/j.automatica.2023.111151⟩. ⟨hal-03668881⟩
182 Consultations
83 Téléchargements
