On the pole placement of scalar linear delay systems with two delays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Mathematical Control and Information Année : 2023
This paper concerns some spectral properties of the scalar dynamical system defined by a linear delay-differential equation with two positive delays. More precisely, the existing links between the delays and the maximal multiplicity of the characteristic roots are explored, as well as the dominance of such roots compared with the spectrum localization. As a by-product of the analysis, the pole placement issue is revisited with more emphasis on the role of the delays as control parameters in defining a partial pole placement guaranteeing the closed-loop stability with an appropriate decay rate of the corresponding dynamical system.
notes_version_finale_arxiv_hal.pdf (447.81 Ko) Télécharger le fichier
hal-03669644 , version 1 (16-05-2022)
hal-03669644 , version 2 (27-02-2023)
Sébastien Fueyo, Guilherme Mazanti, Islam Boussaada, Yacine Chitour, Silviu-Iulian Niculescu. On the pole placement of scalar linear delay systems with two delays. IMA Journal of Mathematical Control and Information, 2023, 40 (1), pp.81-105. ⟨10.1093/imamci/dnad001⟩. ⟨hal-03669644v2⟩
201 Consultations
134 Téléchargements
