One vote is enough for analysing privacy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Stéphanie Delaune
Joseph Lallemand
Electronic voting promises the possibility of convenient and efficient systems for recording and tallying votes in an election. To be widely adopted, ensuring the security of the cryptographic protocols used in e-voting is of paramount importance. However, the security analysis of this type of protocols raises a number of challenges, and they are often out of reach of existing verification tools. In this paper, we study vote privacy, a central security property that should be satisfied by any e-voting system. More precisely, we propose the first formalisation of the state-of-the-art BPRIV notion in the symbolic setting. To ease the formal security analysis of this notion, we propose a reduction result allowing one to bound the number of voters and ballots needed to mount an attack. Our result applies on a number of case studies including several versions of Helios, Belenios, JCJ/Civitas, and Prêt-à-Voter. For some of these protocols, thanks to our result, we are able to conduct the analysis relying on the automatic tool Proverif.
main-long.pdf (616.75 Ko) Télécharger le fichier
esorics-models.zip (67.95 Ko) Télécharger le fichier
hal-03669664 , version 1 (26-05-2022)
  • HAL Id : hal-03669664 , version 1
Stéphanie Delaune, Joseph Lallemand. One vote is enough for analysing privacy. ESORICS 2022 - 27th European Symposium on Research in Computer Security, Sep 2022, Copenhague, Denmark. ⟨hal-03669664⟩
182 Consultations
144 Téléchargements
