Focusing of internal tides by near-inertial waves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Geophysical Research Letters Année : 2017
The refraction of internal waves by lower-frequency near-inertial waves has been predicted theoretically, but never observed before. Here, we report observations of semi-diurnal internal tides generated by the rough topography of the Central Indian Ridge, in the presence of a strong, lower-frequency near-inertial wave field generated by a tropical storm. The semi-diurnal internal tide energy is trapped within upward propagating bands with a periodicity close to the inertial period. A ray-tracing model suggests that this trapping results from the internal tide refraction by the shear associated with near-inertial waves. This yields a strong increase of the internal tide energy and shear in space-time regions where the background flow focuses the rays, leading to the formation of caustics. This mechanism may increase vertical mixing generated by baroclinic tides in the vicinity of mid-ocean ridges in tropical regions.
Cuypers_et_al-2017-Geophysical_Research_Letters.pdf (800.17 Ko) Télécharger le fichier
hal-01489205 , version 1 (14-03-2017)
Copyright (Tous droits réservés)
Yannis Cuypers, Pascale Bouruet-Aubertot, Jérôme Vialard, Michael J. Mcphaden. Focusing of internal tides by near-inertial waves. Geophysical Research Letters, 2017, 44 (5), pp.2398-2406. ⟨10.1002/2017GL072625⟩. ⟨hal-01489205⟩
214 Consultations
315 Téléchargements
