Solving Morphological Analogies Through Generation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This contribution is a first attempt at solving morphological analogies through generation, instead of relying on retrieval approaches. Our preliminary experiments show promising results for some languages and reveal the feasibility of the approach in generating solutions of analogical equations in the morphology setting.
IARML_IJCAI22_GenMorpho.pdf (250.76 Ko) Télécharger le fichier
hal-03674913 , version 1 (21-05-2022)
  • HAL Id : hal-03674913 , version 1
Kevin Chan, Shane Peter Kaszefski-Yaschuk, Camille Saran, Esteban Marquer, Miguel Couceiro. Solving Morphological Analogies Through Generation. IJCAI-ECAI Workshop on the Interactions between Analogical Reasoning and Machine Learning (IARML@IJCAI-ECAI 2022), Miguel Couceiro and Pierre-Alexandre Murena, Jul 2022, Vienna, Austria. pp.29-39. ⟨hal-03674913⟩
107 Consultations
125 Téléchargements
