Association of APOE-Independent Alzheimer Disease Polygenic Risk Score With Brain Amyloid Deposition in Asymptomatic Older Adults
Background and objectives: Brain amyloid deposition, a major risk factor for Alzheimer’s disease (AD), is currently estimated by measuring cerebrospinal fluid or plasma amyloid peptide levels, or by positron-emission tomography imaging. Assessing genetic risks relating to amyloid deposition before any accumulation has occurred would allow for earlier intervention in persons at increased risk for developing AD. Previous work linking amyloid burden and genetic risk relied almost exclusively on APOE, a major AD genetic risk factor. Here, we ask whether a polygenic risk score (PRS) that incorporates an optimized list of common variants linked to AD and excludes APOE is associated with brain amyloid load in cognitively unimpaired elderly adults.
Methods: We included 291 elderly asymptomatic participants from the INveStIGation of AlzHeimer’s PredicTors (INSIGHT-preAD) cohort who underwent amyloid imaging, including 83 amyloid-positive (+) participants. We used an Alzheimer’s (A) PRS composed of 33 AD risk variants excluding APOE, and selected the 17 variants that showed the strongest association with amyloid positivity to define an optimized (oA) PRS. Participants from the Alzheimer’s Disease Neuroimaging Initiative (ADNI) study [228 participants, 90 amyloid (+)] were tested as a validation cohort. Finally, 2,300 AD patients and 6,994 controls from the European Alzheimer's Disease Initiative (EADI) were evaluated.
Results: A-PRS was not significantly associated with amyloid burden in the INSIGHT or ADNI cohorts with or without correction for APOE genotype. However, oA-PRS was significantly associated with amyloid status independently of APOE adjustment (INSIGHT OR: 5.26 [1.71-16.88]; ADNI OR: 3.38 [1.02-11.63]). Interestingly, oA-PRS accurately discriminated amyloid (+) and (–) APOE ε4 carriers (INSIGHT OR: 181.6 [7.53-10,674.6]; ADNI OR: 44.94 [3.03-1,277]). A-PRS and oA-PRS showed a significant association with disease status in the EADI cohort (OR: 1.68 [1.53-1.85] and 2.06 [1.73-2.45] respectively). Genes assigned to oA-PRS variants were enriched in ontologies related to Aβ metabolism and deposition.
Discussion: PRSs relying on AD genetic risk factors excluding APOE may improve risk prediction for brain amyloid, allowing stratification of cognitively unimpaired individuals at risk of AD independent of their APOE status.
Origine : Publication financée par une institution
