Functional annotation of human cognitive states using deep graph convolution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue NeuroImage Année : 2021
A key goal in neuroscience is to understand brain mechanisms of cognitive functions. An emerging approach is “brain decoding”, which consists of inferring a set of experimental conditions performed by a participant, using pattern classification of brain activity. Few works so far have attempted to train a brain decoding model that would generalize across many different cognitive tasks drawn from multiple cognitive domains. To tackle this problem, we proposed a multidomain brain decoder that automatically learns the spatiotemporal dynamics of brain response within a short time window using a deep learning approach. We evaluated the decoding model on a large population of 1200 participants, under 21 different experimental conditions spanning six different cognitive domains, acquired from the Human Connectome Project task-fMRI database. Using a 10s window of fMRI response, the 21 cognitive states were identified with a test accuracy of 90% (chance level 4.8%). Performance remained good when using a 6s window (82%). It was even feasible to decode cognitive states from a single fMRI volume (720ms), with the performance following the shape of the hemodynamic response. Moreover, a saliency map analysis demonstrated that the high decoding performance was driven by the response of biologi- cally meaningful brain regions. Together, we provide an automated tool to annotate human brain activity with fine temporal resolution and fine cognitive granularity. Our model shows potential applications as a reference model for domain adaptation, possibly making contributions in a variety of domains, including neurological and psychiatric disorders.
1-s2.0-S1053811921001245-main.pdf (3.48 Mo) Télécharger le fichier
hal-03684075 , version 1 (15-09-2022)
Paternité
Yu Zhang, Loïc Tetrel, Bertrand Thirion, Pierre Bellec. Functional annotation of human cognitive states using deep graph convolution. NeuroImage, 2021, 231, pp.117847. ⟨10.1016/j.neuroimage.2021.117847⟩. ⟨hal-03684075⟩
46 Consultations
40 Téléchargements
