Joint Scheduling, Routing and Gateway Designation in Real-Time TSCH Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This research proposes a co-design framework for scheduling, routing and gateway designation to improve the real-time performance of low-power wireless mesh networks. We target time-synchronized channel hopping (TSCH) networks with centralized network management and a single gateway. The end goal is to exploit existing trade-offs between the three dimensions to enhance traffic schedulability at systems’ design time. The framework we propose considers a global Earliest-Deadline-First (EDF) scheduler that operates in conjunction with the minimal-overlap (MO) shortest-path routing, after a centrality-driven gateway designation is concluded. Simulation results over varying settings suggest our approach can lead to optimal or near-optimal real-time network performance, with 3 times more schedulable flows than a naive real-time configuration.
gutierrez22joint.pdf (375.68 Ko) Télécharger le fichier
hal-03685331 , version 1 (03-06-2022)
  • HAL Id : hal-03685331 , version 1
Miguel Gutiérrez Gaitán, Luis Almeida, Thomas Watteyne, Pedro M. d'Orey, Pedro M. Santos, et al.. Joint Scheduling, Routing and Gateway Designation in Real-Time TSCH Networks. RTNS 2022 - 30th International Conference on Real-Time Networks and Systems, Jun 2022, Paris, France. ⟨hal-03685331⟩
117 Consultations
104 Téléchargements
