Computational Design of Laser-Cut Bending-Active Structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer-Aided Design Année : 2022
We propose a method to automatically design bending-active structures, made of wood, whose silhouettes at equilibrium match desired target curves. Our approach is based on the use of a parametric pattern that is regularly laser-cut on the structure and that allows us to locally modulate the bending stiffness of the material. To make the problem tractable, we rely on a two-scale approach where we first compute the mapping between the average mechanical properties of periodically laser-cut samples of mdf wood, treated here as metamaterials, and the stiffness parameters of a reduced 2D model; then, given an input target shape, we automatically select the parameters of this reduced model that give us the desired silhouette profile. We validate our method both numerically and experimentally by fabricating a number of full scale structures of varied target shapes.
paper.pdf (40.34 Mo) Télécharger le fichier
SPM22-BestPaperAward.pdf (753.65 Ko) Télécharger le fichier
Format : Figure, Image
Commentaire : Vignette
hal-03687416 , version 1 (03-06-2022)
Emmanuel Rodriguez, Georges-Pierre Bonneau, Stefanie Hahmann, Mélina Skouras. Computational Design of Laser-Cut Bending-Active Structures. Computer-Aided Design, 2022, (SPM 2022), 151 (103335), pp.1-12. ⟨10.1016/j.cad.2022.103335⟩. ⟨hal-03687416⟩
286 Consultations
64 Téléchargements
