Convergence rate of general entropic optimal transport costs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Calculus of Variations and Partial Differential Equations Année : 2023
We investigate the convergence rate of the optimal entropic cost vε to the optimal transport cost as the noise parameter ε↓0. We show that for a large class of cost functions c on Rd×Rd (for which optimal plans are not necessarily unique or induced by a transport map) and compactly supported and L᪲ marginals, one has vε − v0 = d/2 εlog(1/ε) + O(ε). Upper bounds are obtained by a block approximation strategy and an integral variant of Alexandrov's theorem. Under an infinitesimal twist condition on c, i.e. invertibility of ∇²xy c, we get the lower bound by establishing a quadratic detachment of the duality gap in d dimensions thanks to Minty's trick.
CPT22_final.pdf (561.08 Ko) Télécharger le fichier
hal-03689945 , version 1 (07-06-2022)
Paternité
Guillaume Carlier, Paul Pegon, Luca Tamanini. Convergence rate of general entropic optimal transport costs. Calculus of Variations and Partial Differential Equations, 2023, 62 (4), pp.116. ⟨10.1007/s00526-023-02455-0⟩. ⟨hal-03689945⟩
87 Consultations
174 Téléchargements
