Existence of surfaces optimizing geometric and PDE shape functionals under reach constraint - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
This article deals with the existence of hypersurfaces minimizing general shape functionals under certain geometric constraints. We consider as admissible shapes orientable hypersurfaces satis- fying a so-called reach condition, also known as the uniform ball property, which ensures C^{1,1} regularity of the hypersurface. In this paper, we revisit and generalise the results of Guo et al and, J. Dalphin. We provide a simpler framework and more concise proofs of some of the results con- tained in these references and extend them to a new class of problems involving PDEs. Indeed, by using the signed distance introduced by Delfour and Zolesio, we avoid the intensive and technical use of local maps, as was the case in the above references. Our approach, originally developed to solve an existence problem in a recent work by the same authors dedicated to optimal shape issues for Plasma Physics, can be easily extended to costs involving different mathematical objects associated with the domain, such as solutions of elliptic equations on the hypersurface.
reach_article.pdf (506.45 Ko) Télécharger le fichier
hal-03690069 , version 1 (07-06-2022)
  • HAL Id : hal-03690069 , version 1
Yannick Privat, Rémi Robin, Mario Sigalotti. Existence of surfaces optimizing geometric and PDE shape functionals under reach constraint. 2022. ⟨hal-03690069⟩
168 Consultations
75 Téléchargements
