Ring Road Networks: Access for Anyone - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Communications Magazine Année : 2022
Several billion people currently lack reliable access to the Internet and thus to a tremendous source of knowledge. In this article, we describe a field-tested communication approach combining CubeSat platforms and delay-tolerant networking (DTN) solutions to provide asynchronous connectivity to populations and regions that are underserved by the Internet. The resulting class of networks is known as ring road networks (RRNs), a networking approach that is built on technology developed for the construction of a solar system Internet. The necessary self-sufficiency of DTN nodes enables network access to be deployed incrementally at low cost, supporting communities that cannot be profitably served by Internet satellite constellations. We present the RRN architecture and evaluate the expected performance by means of simulations. Based on the latter, we discuss mD3TN: a lightweight and open source DTN protocol stack for RRNs and other DTN classes. mD3TN has been flight-tested in ESA's OPS-SAT in low Earth orbit during December 2020 and May 2021. This work discusses the experiment results as we validated the RRN approach in concrete application use cases. The reported outcomes motivate a new application domain.
_IEEE_Comms_Mag_Final__Ring_Road_Networks__Final_Doc_.pdf (1.94 Mo) Télécharger le fichier
hal-03692361 , version 1 (10-06-2022)
Marius Feldmann, Juan Fraire, Felix Walter, Scott Burleigh. Ring Road Networks: Access for Anyone. IEEE Communications Magazine, 2022, 60 (4), pp.38-44. ⟨10.1109/MCOM.001.2100835⟩. ⟨hal-03692361⟩
52 Consultations
223 Téléchargements
