Privacy Preserving Image Registration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Image registration is a key task in medical imaging applications, allowing to represent medical images in a common spatial reference frame. Current literature on image registration is generally based on the assumption that images are usually accessible to the researcher, from which the spatial transformation is subsequently estimated. This common assumption may not be met in current practical applications, since the sensitive nature of medical images may ultimately require their analysis under privacy constraints, preventing to share the image content in clear form. In this work, we formulate the problem of image registration under a privacy preserving regime, where images are assumed to be confidential and cannot be disclosed in clear. We derive our privacy preserving image registration framework by extending classical registration paradigms to account for advanced cryptographic tools, such as secure multi-party computation and homomorphic encryption, that enable the execution of operations without leaking the underlying data. To overcome the problem of performance and scalability of cryptographic tools in high dimensions, we first propose to optimize the underlying image registration operations using gradient approximations. We further revisit the use of homomorphic encryption and use a packing method to allow the encryption and multiplication of large matrices more efficiently. We demonstrate our privacy preserving framework in linear and nonlinear registration problems, evaluating its accuracy and scalability with respect to standard image registration. Our results show that privacy preserving image registration is feasible and can be adopted in sensitive medical imaging applications.
Privacy_Preserving_Image_Registration.pdf (472.53 Ko) Télécharger le fichier
hal-03697446 , version 1 (16-06-2022)
hal-03697446 , version 2 (28-06-2022)
hal-03697446 , version 3 (18-09-2022)
  • HAL Id : hal-03697446 , version 3
Riccardo Taiello, Melek Önen, Olivier Humbert, Marco Lorenzi. Privacy Preserving Image Registration. MICCAI 2022 - Medical Image Computing and Computer Assisted Intervention, Sep 2022, Singapore, Singapore. ⟨hal-03697446v3⟩
124 Consultations
91 Téléchargements
