Enhanced low-frequency microwave absorption performance of FeNi alloy coated carbon foam assisted by SiO2 layer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Surface Science Année : 2022
The hierarchical structures of carbonized melamine foam modified by FeNi alloy and silicon layer (CMF/FeNi-SiO 2) have been fabricated by a magnetron sputtering method. The as-prepared CMF/FeNi-SiO 2 composites exhibited a three-dimensional porous structure, with the framework uniformly covered by a 150~400 nm FeNi layer and an ultrathin SiO 2 layer, which demonstrated soft magnetic properties at room temperature. Moreover, the microwave absorption performance of the foam was investigated in the frequency range from 2 to 18 GHz. The results showed that the microwave absorption performance of CMF/FeNi-SiO 2 composite was significantly enhanced in the low-frequency range compared with CMF/FeNi. The minimum reflection loss of CMF/FeNi-SiO 2 with an absorption thickness of 4.1 mm was about −53 dB at 3.38 GHz and reached an effective absorption bandwidth of 0.93 GHz (from 2.93 GHz to 3.86 GHz). The frequency bandwidth of 4 GHz (2.35~6.35 GHz) with absorption loss ≤ −10 dB and the frequency bandwidth of 2.05 GHz (2.62~4.67 GHz) with absorption loss ≤-20 dB demonstrated the CMF/FeNi-SiO 2 a high-efficient absorber in the low-frequency band (2-6 GHz), which stemmed from improved impedance matching and attenuation capacities.
Enhanced low-frequency microwave absorption performance of FeNi alloy coated carbon foam assisted by SiO2 layer.pdf (7.57 Mo) Télécharger le fichier
hal-03706516 , version 1 (27-06-2022)
Yangjun Zou, Xiaozhong Huang, Benhui Fan, Jianling Yue, Yu Liu. Enhanced low-frequency microwave absorption performance of FeNi alloy coated carbon foam assisted by SiO2 layer. Applied Surface Science, In press, ⟨10.1016/j.apsusc.2022.154046⟩. ⟨hal-03706516⟩
Collections
CEREMA
53 Consultations
86 Téléchargements
