Event-Triggered Control for Continuous-Time Linear Systems with a Delay in the Input - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2022
We provide an event-triggered control technique for a family of linear time-varying continuous-time systems with a constant known pointwise delay in the input. We adopt a subpredictor based prediction technique, and we provide sufficient conditions that ensure that Zeno behavior does not occur. At each time, only delayed measurements are needed to implement the control. Also, the delay can be an arbitrarily large constant. We prove an input-to-state stability property for the closed-loop system, using the theory of cooperative systems. We apply our method to a gyroscopic control problem for a curve tracking dynamics arising in marine robotics.
Automatique
ChainPredictorEventTriggeredfmcb.pdf (528.99 Ko) Télécharger le fichier
hal-03711589 , version 1 (01-07-2022)
Frederic Mazenc, Michael Malisoff, Corina Barbalata. Event-Triggered Control for Continuous-Time Linear Systems with a Delay in the Input. Systems and Control Letters, 2022, ⟨10.1016/j.sysconle.2021.105075⟩. ⟨hal-03711589⟩
46 Consultations
200 Téléchargements
