High-Dimensional Private Empirical Risk Minimization by Greedy Coordinate Descent - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
In this paper, we study differentially private empirical risk minimization (DP-ERM). It has been shown that the worst-case utility of DP-ERM reduces polynomially as the dimension increases. This is a major obstacle to privately learning large machine learning models. In high dimension, it is common for some model's parameters to carry more information than others. To exploit this, we propose a differentially private greedy coordinate descent (DP-GCD) algorithm. At each iteration, DP-GCD privately performs a coordinate-wise gradient step along the gradients' (approximately) greatest entry. We show theoretically that DP-GCD can achieve a logarithmic dependence on the dimension for a wide range of problems by naturally exploiting their structural properties (such as quasi-sparse solutions). We illustrate this behavior numerically, both on synthetic and real datasets.
paper.pdf (769.15 Ko) Télécharger le fichier
hal-03714465 , version 1 (05-07-2022)
hal-03714465 , version 2 (21-10-2022)
hal-03714465 , version 3 (09-04-2023)
  • HAL Id : hal-03714465 , version 2
Paul Mangold, Aurélien Bellet, Joseph Salmon, Marc Tommasi. High-Dimensional Private Empirical Risk Minimization by Greedy Coordinate Descent. 2022. ⟨hal-03714465v2⟩
143 Consultations
72 Téléchargements
