Numerical convergence of some stochastic compartmental models in epidemiology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a numerical study to analyse the convergence of some stochastic models including some parameter estimation using classical estimation procedure. We illustrate the convergence of a continuous time Markov chain, a Poisson stochastic model, to a deterministic model. Simulations highlight the differences in the speed of convergence of the stochastic models considered. We end with a discussion on some forthcoming theoretical developments.
tsilefa_raherinirina_cari2022.pdf (4.25 Mo) Télécharger le fichier
hal-03715840 , version 1 (06-07-2022)
  • HAL Id : hal-03715840 , version 1
Stefana Fandresena Tsilefa, Solym Manou-Abi, Angelo Raherinirina. Numerical convergence of some stochastic compartmental models in epidemiology. CARI 2022, Oct 2022, Tunis, Tunisia. ⟨hal-03715840⟩
138 Consultations
76 Téléchargements
