Dynamical Synapses in Retinal Surprise coding
• Stimulation a dissected retina with a sequence of periodic dark flashes • Extracellular spike recordings. 2. Identification of necessary components via pharmacological inhibition of synaptic transmission onto : • ON bipolar cells via mGluR6 receptor antagonist LAP-4. • OFF bipolar cells via AMPA receptor antagonist ACET. Results ON BC inhibition cancels the OSR.
