Approximating robot reachable space using convex polytopes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents an approach for approximating the reachable space of robotic manipulators based on convex polytopes. The proposed approach predicts the reachable space over a given time horizon based on the robot's actuation limits and kinematic constraints. The approach is furthermore extended to integrate the robot's environment, assuming it can be expressed in a form of linear constraints, and to account for the robot's link geometry. The accuracy of the proposed method is evaluated using simulations of robot's nonlinear dynamics and it is compared against the cartesian space limits, usually provided by manufacturers in standard datasheets. The accuracy analysis results show that the proposed method has good performance for the time horizons up to 250ms, encapsulating most of the simulated robot's reachable space while maintaining comparable volume. For a 7 dof robot, the method has an average execution time of 50ms, independent of the horizon time, potentially enabling real-time applications.
samplepaper.pdf (1.52 Mo) Télécharger le fichier
hal-03719885 , version 1 (11-07-2022)
hal-03719885 , version 2 (24-09-2022)
hal-03719885 , version 3 (29-11-2022)
Antun Skuric, Vincent Padois, David Daney. Approximating robot reachable space using convex polytopes. 15th International Workshop on Human-Friendly Robotics, Sep 2022, Delft, Netherlands. ⟨hal-03719885v3⟩
127 Consultations
131 Téléchargements
