A Route-based Method for Turning Ratio Estimation: Application to the Grenoble Downtown Traffic Flow and Density Reconstruction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we propose a route-based approach to improve the flow and density estimation methods for the case of urban traffic networks. For this proposal, a traffic assignment problem is solved at first, whose outputs are used to estimate the turning ratios for all intersections. Such information is not usually available at each node of the network. Second, the estimated turning ratios are used to better reconstruct the dynamic state of the network: the flow and density. To validate the proposed methods, we use real traffic data collected in the city of Grenoble in France, which include the measurement of Origin-Destination matrices, some turning ratios for validation, mean speeds of road sections and traffic flows at the boundaries of the network.
CDC22_TR_Estimation_MRV_CDW_HF.pdf (2.75 Mo) Télécharger le fichier
hal-03727315 , version 1 (19-07-2022)
Martin Rodriguez-Vega, Carlos Canudas de Wit, Hassen Fourati. A Route-based Method for Turning Ratio Estimation: Application to the Grenoble Downtown Traffic Flow and Density Reconstruction. CDC 2022 - 61st IEEE Conference on Decision and Control, Dec 2022, Cancun, Mexico. pp.1-7, ⟨10.1109/CDC51059.2022.9993075⟩. ⟨hal-03727315⟩
76 Consultations
64 Téléchargements
