Eyring-Kramers exit rates for the overdamped Langevin dynamics: the case with saddle points on the boundary - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Let $(X_t)_{t\ge 0}$ be the stochastic process solution to the overdamped Langevin dynamics $$dX_t=-\nabla f(X_t) \, dt +\sqrt h \, dB_t$$ and let $\Omega \subset \mathbb R^d $ be the basin of attraction of a local minimum of $f: \mathbb R^d \to \mathbb R$. Up to a small perturbation of $\Omega$ to make it smooth, we prove that the exit rates of $(X_t)_{t\ge 0}$ from $\Omega$ through each of the saddle points of $f$ on $\partial \Omega$ can be parametrized by the celebrated Eyring-Kramers laws, in the limit $h \to 0$. This result provides firm mathematical grounds to jump Markov models which are used to model the evolution of molecular systems, as well as to some numerical methods which use these underlying jump Markov models to efficiently sample metastable trajectories of the overdamped Langevin dynamics.
hal-03728053 , version 1 (20-07-2022)
Tony Lelièvre, Dorian Le Peutrec, Boris Nectoux. Eyring-Kramers exit rates for the overdamped Langevin dynamics: the case with saddle points on the boundary. 2022. ⟨hal-03728053⟩
122 Consultations
0 Téléchargements
