Failing to hash into supersingular isogeny graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
An important open problem in supersingular isogeny-based cryptography is to produce, without a trusted authority, concrete examples of ''hard supersingular curves,'' that is, concrete supersingular curves for which computing the endomorphism ring is as difficult as it is for random supersingular curves. Or, even better, to produce a hash function to the vertices of the supersingular ℓ-isogeny graph which does not reveal the endomorphism ring, or a path to a curve of known endomorphism ring. Such a hash function would open up interesting cryptographic applications. In this paper, we document a number of (thus far) failed attempts to solve this problem, in the hopes that we may spur further research, and shed light on the challenges and obstacles to this endeavour. The mathematical approaches contained in this article include: (i) iterative root-finding for the supersingular polynomial; (ii) gcd's of specialized modular polynomials; (iii) using division polynomials to create small systems of equations; (iv) taking random walks in the isogeny graph of abelian surfaces; and (v) using quantum random walks.
Fichier non déposé
hal-03739041 , version 1 (26-07-2022)
  • HAL Id : hal-03739041 , version 1
Jeremy Booher, Ross Bowden, Javad Doliskani, Tako Boris Fouotsa, Steven Galbraith, et al.. Failing to hash into supersingular isogeny graphs. 2022. ⟨hal-03739041⟩
40 Consultations
0 Téléchargements
