An Implementation of Set Theory with Pointed Graphs in Dedukti - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
DEDUKTI is a type-checker for the λ Π-calculus modulo theory, a logical framework that allows the extension of conversion with user-defined rewrite rules. In this paper, we present the implementation of a version of Dowek-Miquel's intuitionistic set theory in DEDUKTI. To do so, we adapt this theory-based on the concept of pointed graphs-from Deduction modulo theory to λ Π-calculus modulo theory, and we formally write the proofs in DEDUKTI. In particular, this implementation requires the definition of a deep embedding of a certain class of formulas, as well as its interpretation in the theory.
deduktiz.pdf (256.85 Ko) Télécharger le fichier
hal-03740004 , version 1 (28-07-2022)
  • HAL Id : hal-03740004 , version 1
Valentin Blot, Gilles Dowek, Thomas Traversié. An Implementation of Set Theory with Pointed Graphs in Dedukti. LFMTP 2022 - International Workshop on Logical Frameworks and Meta-Languages : Theory and Practice, Aug 2022, Haïfa, Israel. ⟨hal-03740004⟩
223 Consultations
180 Téléchargements
