A 2D image-based multiphysics model for lifetime evaluation and failure scenario analysis of self-healing ceramic-matrix mini-composites under a tensile load - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the European Ceramic Society Année : 2022
We propose a multi-physics numerical model for a self-healing ceramic matrix mini-composite under tensile load. Crack averaged PDEs are proposed for the transport of oxygen and of all the chemical species involved in the healing process and studied in the dimensionless form to perform the most appropriate discretization choices concerning time integration, and boundary conditions. Concerning the fibres’ degradation, a slow crack growth model explicitly dependent on the environmental parameters is calibrated using a particular exact solution and integrated numerically in the general case. The tow failure results from the statistical distribution of the fibres’ initial strength, the slow crack growth kinetics, and the load transfer following fibres breakage. The lifetime prediction capabilities of the model, as well as the effect of temperature, spatial variation of the statistical distribution of fibres strength, and applied load, are investigated highlighting the influence of the diffusion/reaction processes (healing) on the fibre breakage scenarios.
jecs2022-author.pdf (868.04 Ko) Télécharger le fichier
hal-03741298 , version 1 (01-08-2022)
Giulia Bellezza, Guillaume Couégnat, Mario Ricchiuto, Gérard L. Vignoles. A 2D image-based multiphysics model for lifetime evaluation and failure scenario analysis of self-healing ceramic-matrix mini-composites under a tensile load. Journal of the European Ceramic Society, 2022, ⟨10.1016/j.jeurceramsoc.2022.07.037⟩. ⟨hal-03741298⟩
140 Consultations
51 Téléchargements
