From Vlasov equation to degenerate nonlocal Cahn-Hilliard equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Mathematical Physics Année : 2023
We provide a rigorous mathematical framework to establish the hydrodynamic limit of the Vlasov model introduced by Noguchi and Takata in order to describe phase transition of fluids by kinetic equations. We prove that, when the scale parameter tends to 0, this model converges to a nonlocal Cahn-Hilliard equation with degenerate mobility. For our analysis, we introduce apropriate forms of the short and long range potentials which allow us to derive Helmhotlz free energy estimates. Several compactness properties follow from the energy, the energy dissipation and kinetic averaging lemmas. In particular we prove a new weak compactness bound on the flux.
kinetic.pdf (435.75 Ko) Télécharger le fichier
hal-03744471 , version 1 (02-08-2022)
Charles Elbar, Marco Mason, Benoît Perthame, Jakub Skrzeczkowski. From Vlasov equation to degenerate nonlocal Cahn-Hilliard equation. Communications in Mathematical Physics, 2023, 401 (1), pp.1033-1057. ⟨10.1007/s00220-023-04663-3⟩. ⟨hal-03744471⟩
61 Consultations
25 Téléchargements
