Poster: Privacy-Aware Decentralized Multi-Slice Traffic Forecasting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2022
In this work, taking the perspective of Mobile Virtual Network Operators (MVNOs), we tackle the multi-slice traffic forecasting problem, while respecting the data privacy of users. To this end, we propose the Federated Proximal Long Short-Term Memory (FPLSTM) framework, which allows MVNOs to train at each base station their local models with their private datasets, without compromising data privacy. Prediction results obtained by evaluating the models on a real-world dataset indicate that the forecast of FPLSTM is as accurate as state-of-the-art solutions while ensuring data privacy as well as computation and communication costs efficiency.
Poster_Mobisys.pdf (836.91 Ko) Télécharger le fichier
hal-03755118 , version 1 (21-08-2022)
  • HAL Id : hal-03755118 , version 1
Hnin Pann Phyu, Diala Naboulsi, Razvan Stanica. Poster: Privacy-Aware Decentralized Multi-Slice Traffic Forecasting. MobiSys 2022 - The 20th ACM International Conference on Mobile Systems, Applications, and Services, Jun 2022, Portland, United States. . ⟨hal-03755118⟩
59 Consultations
35 Téléchargements
