Penalized polytomous ordinal logistic regression using cumulative logits. Application to network inference of zero-inflated variables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We consider the problem of variable selection when the response is ordinal, that is an ordered categorical variable. In particular, we are interested in selecting quantitative explanatory variables linked with the ordinal response variable and we want to determine which predictors are relevant. In this framework, we choose to use the polytomous ordinal logistic regression model using cumulative logits which generalizes the logistic regression. We then introduce the Lasso estimation of the regression coefficients using the Frank-Wolfe algorithm. To deal with the choice of the penalty parameter, we use the stability selection method and we develop a new method based on the knockoffs idea. This knockoffs method is general and suitable to any regression and besides, gives an order of importance of the covariates. Finally, we provide some experimental results to corroborate our method. We then present an application of this regression method for network inference of zero-inflated variables and use it in practice on real abundance data in an agronomic context.
Karman2018.pdf (570.81 Ko) Télécharger le fichier
hal-03757473 , version 1 (22-08-2022)
  • HAL Id : hal-03757473 , version 1
Aurélie Deveau, Anne Gégout-Petit, Clémence Karmann. Penalized polytomous ordinal logistic regression using cumulative logits. Application to network inference of zero-inflated variables. 2022. ⟨hal-03757473⟩
48 Consultations
43 Téléchargements
