Minimizing I/Os in Out-of-Core Task Tree Scheduling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Foundations of Computer Science Année : 2023
Scientific applications are usually described using directed acyclic graphs, where nodes represent tasks and edges represent dependencies between tasks. For some applications, this graph is a tree: each task produces a single result used solely by its parent. The temporary results of each task have to be stored between their production and their use. We focus on the case when the data manipulated are very large. Then, during an execution, all data may not fit together in memory. In such a case, some data have to be temporarily written to disk and evicted from memory. These data are later read from disk when they are needed for computation. These Input/Output operations are very expensive; hence, our goal is to minimize their total volume. The order in which the tasks are processed considerably influences the amount of such Input/Output operations. Finding the schedule which minimizes this amount is an open problem that we revisit in this paper. We first formalize and generalize known results, and prove that existing solutions can be arbitrarily worse than the optimal. We then present an Integer Linear Program to solve it optimally. Finally, we propose a novel heuristic algorithm. We demonstrate its good performance through simulations on both synthetic and realistic trees built from actual scientific applications.
ijfcs.pdf (580.57 Ko) Télécharger le fichier
hal-03758021 , version 1 (13-09-2022)
Paternité
Loris Marchal, Samuel McCauley, Bertrand Simon, Frédéric Vivien. Minimizing I/Os in Out-of-Core Task Tree Scheduling. International Journal of Foundations of Computer Science, 2023, 34 (01), pp.51-80. ⟨10.1142/s0129054122500186⟩. ⟨hal-03758021⟩
79 Consultations
67 Téléchargements
