An unsupervised domain adaptation brain CT segmentation method across image modalities and diseases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Expert Systems with Applications Année : 2022
Computed tomography (CT) is the primary diagnostic tool for brain diseases. To determine the appropriate treatment plan, it is necessary to ascertain the patient's bleeding volume. Automatic segmentation algorithms for hemorrhagic lesions can significantly improve efficiency and avoid treatment delays. However, for deep supervised learning algorithms, a large amount of labeled training data is usually required, making them difficult to apply clinically. In this study, we propose an unsupervised domain adaptation method that is an unsupervised domain adaptation segmentation model that can be trained across modalities and diseases. We call it AMD-DAS for brain CT hemorrhage segmentation tasks. This circumvents the heavy data labeling task by converting the source domain data (MRI with glioma) to our task's required data (CT with Intraparenchymal hemorrhage (IPH)). Our model implements a two-stage domain adaptation process to achieve this objective. In the first stage, we train a pseudo-CT image synthesis network using the CycleGAN architecture through a matching mechanism and domain adaptation approach. In the second stage, we use the model trained in the first stage to synthesize the pseudo-CT images. We use the pseudo-CT with source domain labels and real CT images to train a domain-adaptation segmentation model. Our method exhibits a better performance than the basic one-stage domain adaptation segmentation method (+11.55 Dice score) and achieves an 86.93 Dice score in the IPH unsupervised segmentation task. Our model can be trained without using a ground-truth label, therefore increasing its application potential. Our implementation is publicly available at https://github.com/GuanghuiFU/AMD-DAS-Brain-CT-Segmentation.
ESWA-Guanghui.pdf (3.05 Mo) Télécharger le fichier
hal-03760531 , version 1 (27-10-2022)
Daqiang Dong, Guanghui Fu, Jianqiang Li, Yan Pei, Yueda Chen. An unsupervised domain adaptation brain CT segmentation method across image modalities and diseases. Expert Systems with Applications, 2022, 207, ⟨10.1016/j.eswa.2022.118016⟩. ⟨hal-03760531⟩
55 Consultations
102 Téléchargements
