A NOTE ON THE DIMENSIONALITY OF MODIFIED KNÖDEL GRAPHS
We show that the edges of the modi ed Kn odel graph can be grouped into dimensions which are similar to the dimensions of hypercubes. In particular, routing, broadcasting and gossiping, can be done easily in modi ed Kn odel graphs using these dimensions.
