Graph Problems arising from Wavelength-routing in All-optical Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1997
This paper surveys the theoretical results obtained for wavelength{routing all{optical networks, presents some new results and proposes several open problems. In all{optical networks the vast bandwidth available is utilized through wavelength division multiplexing: a single physical optical link can carry several logical signals, provided that they are transmitted on di erent wavelengths. The information, once transmitted as light, reaches its destination without being converted to electronic form inbetween, thus reaching high communication speed. We consider both networks with arbitrary topologies and particular networks of practical interest.
118-BBG+97-surveygraphsWDM.pdf (241.45 Ko) Télécharger le fichier
hal-03764663 , version 1 (30-08-2022)
  • HAL Id : hal-03764663 , version 1
Bruno Beauquier, Jean-Claude Bermond, Luisa Gargano, Pavol Hell, Stéphane Pérennes, et al.. Graph Problems arising from Wavelength-routing in All-optical Networks. WOCS 1997 - 2nd Workshop on Optics and Computer Science - 11th International Parallel Processing Symposium, Apr 1997, Geneve, Switzerland. ⟨hal-03764663⟩
93 Consultations
7 Téléchargements
