Robust estimation of fundamental frequency positive-sequence component for grid-integration applications in energy systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This article studies the problem of fundamental frequency positive-sequence component separation in unbalanced three-phase systems for grid-integration applications. We propose a-simple-to-implement approach involving a modified delayed signal cancellation method and moving average filtering. A delay-based linear-regression framework is considered to make the sequence component separation frequency-adaptive, providing fast and accurate frequency estimation. Comparative experimental results demonstrate the suitability of the proposed method over conventional approaches.
_RE-859.pdf (788.75 Ko) Télécharger le fichier
hal-03766158 , version 1 (31-08-2022)
  • HAL Id : hal-03766158 , version 1
Hafiz Ahmed, Rosane Ushirobira, Denis Efimov. Robust estimation of fundamental frequency positive-sequence component for grid-integration applications in energy systems. The 5th International Conference on Renewable Energy and Environment Engineering, Aug 2022, Brest, France. ⟨hal-03766158⟩
26 Consultations
45 Téléchargements
