Lipschitz continuity of the Wasserstein projections in the convex order on the line - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Communications in Probability Année : 2023
Wasserstein projections in the convex order were first considered in the framework of weak optimal transport, and found application in various problems such as concentration inequalities and martingale optimal transport. In dimension one, it is well-known that the set of probability measures with a given mean is a lattice w.r.t. the convex order. Our main result is that, contrary to the minimum and maximum in the convex order, the Wasserstein projections are Lipschitz continuity w.r.t. the Wasserstein distance in dimension one. Moreover, we provide examples that show sharpness of the obtained bounds for the 1-Wasserstein distance.
hal-03768703 , version 1 (04-09-2022)
Paternité
Benjamin Jourdain, William Margheriti, Gudmund Pammer. Lipschitz continuity of the Wasserstein projections in the convex order on the line. Electronic Communications in Probability, 2023, 28 (none), ⟨10.1214/23-ECP525⟩. ⟨hal-03768703⟩
68 Consultations
0 Téléchargements
