Hamiltonian formulation of the stochastic surface wave problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences Année : 2022
We devise a stochastic Hamiltonian formulation of the water wave problem. This stochastic representation is built within the framework of the modelling under location uncertainty. Starting from restriction to the free surface of the general stochastic fluid motion equations, we show how one can naturally deduce Hamiltonian structure under a small noise assumption. Moreover, as in the classical water wave theory, the non-local Dirichlet-Neumann operator appears explicitly in the energy functional. This, in particular, allows us, in the same way as in deterministic setting, to conduct systematic approximations of the Dirichlet-Neumann operator and to infer di↵erent simplified wave models including noise in a natural way.
Dinvay-Memin-Proc-Roy-Soc-22.pdf (1.25 Mo) Télécharger le fichier
hal-03777888 , version 1 (15-09-2022)
Evgueni Dinvay, Etienne Mémin. Hamiltonian formulation of the stochastic surface wave problem. Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, 2022, pp.1-26. ⟨10.1098/rspa.2022.0050⟩. ⟨hal-03777888⟩
30 Consultations
28 Téléchargements
