An Interval Observer for Continuous-Time Persidskii Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper deals with design of interval observers for a class of generalized Persidskii systems. The conditions of stability for the suggested nonlinear interval observer are formulated using linear matrix inequalities. The nonnegativity of this class of models is investigated for nonlinearities satisfying the incremental passivity conditions. The efficiency of the proposed observer is demonstrated on a Lotka-Volterra model.
Interval_Pers.pdf (514.86 Ko) Télécharger le fichier
hal-03778043 , version 1 (15-09-2022)
  • HAL Id : hal-03778043 , version 1
Denis Efimov, Andrey Polyakov, Xubin Ping. An Interval Observer for Continuous-Time Persidskii Systems. Proc. 61th IEEE Conference on Decision and Control (CDC), Dec 2022, Cancún, Mexico. ⟨hal-03778043⟩
35 Consultations
52 Téléchargements
