Thermoviscous acoustic propagation in thin rough tubes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thermoviscous acoustic propagation in a tube with corrugated isothermal rigid walls is considered. At long wavelengths, it amounts to a 1D transmission line equation, in which the coefficients depend on the solution to a 2D diffusion problem. These coefficients are shown to display predictable behaviors at low, high, and intermediate frequencies. These results are demonstrated on a numerical example.
THIBAULT_WAVES2022.pdf (416.32 Ko) Télécharger le fichier
hal-03780126 , version 1 (19-09-2022)
  • HAL Id : hal-03780126 , version 1
Henri Boutin, Juliette Chabassier, Thomas Hélie, Alexis Thibault. Thermoviscous acoustic propagation in thin rough tubes. WAVES 2022 - 15th International Conference on Mathematical and Numerical Aspects of Wave Propagation, Jul 2022, Palaiseau, France. ⟨hal-03780126⟩
50 Consultations
64 Téléchargements
