From a collection of documents to a published edition : how to use an end-to-end publication pipeline - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The goal of the workshop is to demonstrate how a corpus could be processed for publication with TEI Publisher. The workshop participants will learn to experiment with a ready-to-use solution that provides an easy and quick publication of a corpus. They will also get tips and shortcuts to help speed up the creation of a digital edition. Moreover, by the end of the session, this workshop will provide the participants with a visualization of their respective corpus, with side by side transformed text and original image; all of which then showing what can be achieved while working with TEI in the context of an end-to-end publication pipeline.
TEI 2022 - Workshop DiScholEd.pdf (90.9 Ko) Télécharger le fichier
slides_workshop_tei2022.pdf (1.02 Mo) Télécharger le fichier
hal-03780316 , version 1 (19-09-2022)
  • HAL Id : hal-03780316 , version 1
Floriane Chiffoleau, Hugo Scheithauer. From a collection of documents to a published edition : how to use an end-to-end publication pipeline. TEI 2022 - Text Encoding Initiative 2022 Conference, Sep 2022, Newcastle, United Kingdom. ⟨hal-03780316⟩
87 Consultations
93 Téléchargements
